Twx 8.5: Clear selected in the map
Hello everybody,
Im trying to clear the selected device when I select this device in the google map widget. I'm trying by several ways but I dont get the correct option. Any can help me?
Thanks in advance,
Luis 😄
slangleyAnswer
Support
Hi @LuisCabello.
Did you check our partner's website for the Google Maps widget?  I understand that they just published an update so even if you downloaded it already, you may want to check the version to verify you have the latest.
--Sharon
Support
Hi @LuisCabello.
What version of Google Maps are you running and where did you obtain it?  We tested this and had the same results.
A PTC Partner is now maintaining and supporting the Google Maps widget.  Here is a link to their website.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @LuisCabello.
--Sharon
