[TWX 9.0.2] Missing Session Variable "Changed"-Event
- 6 replies
- 3137 views
- Translate All
I've exported a project from TWX 8.5.4 to 9.0.2 which is working fine so far. But there is one issue: I can't figure out how to bind the "Changed"-Event from a session variable in TWX 9. There is simply no menu to do it. I've attached two screenshot from 8.5.4 and 9.0.2 where you see that the event "ToggleVarChanged" show up when you click on the session variable in the "Session" tab. Since 9.0.0 this isn't the case anymore and I don't see another option.
The binding itself (created in 8.5) is still working in 9.0 and is shown in the mashup builder.
So... any ideas where to look for it?
