Nov 14, 2017 7:24 PM UTC
TWX_Salesforce_Connector_ExtensionPackage location
I'm attempting to connect to SalesForce through ThingWorx 8.0.0-b11 but I'm having trouble finding the TWX_Salesforce_Connector_ExtensionPackage that is described in this support document:  ThingWorx Converge Help Center.  I have Utilities installed but I've been unable to locate anything related to a SalesForce connector or another extension that I can install.  Additionally, the document mentions a dependency on another extension that aids in Authentication.
Thank you.
posipovaAnswer
20-Turquoise
Nov 14, 2017 8:23 PM UTC
Confirmed, the documentation for ThingWorx 7.x needs to be updated to match. The extension is no longer available.
20-Turquoise
Nov 14, 2017 7:44 PM UTC
There is a support ticket opened on the same issue/question. I will update this thread once we get a definite answer. Seems like this might be a non-existent extension used as an example but the documentation is worded poorly to reflect that.
nmilleson17-PeridotAuthor
Nov 14, 2017 7:48 PM UTC
There is also reference to a SalesForce resource in the Utilities Installation Guide regarding updating utilities.  I cannot find any of these resources within the Composer environment either:
• Salesforce ○ PTC.Resource.CRM.SalesforceAccountResourceProvider, TWUTL: ResourceProvider ○ PTC.Resource.CRM.SalesforceAccountDataShape, TWUTL: ResourceProvider ○ PTC.Resource.CRM.SalesforceContactResourceProvider, TWUTL: ResourceProvider ○ PTC.Resource.CRM.SalesforceContactDataShape, TWUTL: ResourceProvider
Found here: http://support.ptc.com/WCMS/files/172616/en/ThingWorxUtilitiesInstall.pdf on Page 25
20-Turquoise
Nov 14, 2017 7:55 PM UTC
I just reached out to the Utilities product owner to get some clarification on this.
I recall we did have a marketplace salesforce integration extension at some point in the past but stopped supporting it.
posipova20-TurquoiseAnswer
20-Turquoise
Nov 14, 2017 8:57 PM UTC
Thanks for looking into that.  I'll explore using the ContentLoaderFunctions instead.
