[TWX9.0] questions about the new schedule chart widget
I was testing around with the new schedule chart widget introduced in TWX 9.0 and had some issues with it:
I set custom colors in the infotable data within the service feeding the chart. But the colors in the legend didn't change. Is this behaviour intended?
Secondly I don't like that the bars change their height when you expand a bar. Is there a way to disable the detail view completely? I can disable the graph to deny any interaction but than i can't use the filter option in the legend.
If there is not such an option it would be handy in future releases to be able to disable this feature.
lbisaxAnswer
I'm not using any custom CSS. I was able to change the colors for both graph and legend via the style properties of the widget. So my "problem" is solved. Thanks anyway 🙂
Support
Hi @lbisax.
Are you using any custom .css that may be affecting the legend?  Can you provide the mashup you're using for this so we can look into it further?
--Sharon
lbisax13-AquamarineAuthorAnswer
