unable to access DEFAULT_END_TIMESTAMP
I implemented a version of the Groovy script shown on the MobileLocation API Reference page as a Custom Object on the Axeda Platform.  I get the following exception when I run this script:
Access to property DEFAULT_END_TIMESTAMP of class com.axeda.drm.services.mobilelocation.MobileLocationImpl not allowed
What is the proper reference to the DEFAULT_END_TIMESTAMP property?
    It appears that a workaround is available for this issue.  You don't need "lake" access if you know that DEFAULT_END_TIMESTAMP = 4136677158944L.
    That API is located in the 6.8 Code Access Policy (CAP) level "lake."  By default all new instances in the On-Demand Center are provisioned in "pond."  "Lake" and "Sea" are progressively more permissive depending on your application requirements.
    I recommend opening a support case to have your CAP level altered to lake.
    -Chris Kaminski
    PTC Customer Support
    ptc-46688181-VisitorAuthorAnswer
    I almost posted that very answer - for while this is true, I'm always leery of recommending someone rely on implementation details like this.
    -Chris Kaminski
