Unable to bind output of a service
I have a service that is triggered based on a different event. The service takes 1 input and outputs an infotable.
When I try to bind a dropdown to the output of this service I don't get any option to bind the service output to a dropdown.
did your output into your service also declare a datashape. in order to continue working here, the form of the infotable must be known at the output, otherwise thingworx doesn't know what it should offer you as options.
Yeah, I got to know it from PTC documentation later.
Thanks a lot for your response.
