unable to connect NODE MCU (Arduino) to thingworx .
Dear reader,
I am trying to connect Node MCU(Arduino) to thingworx as per the tutorial ,but i am unable to push the value to thingworx.please go throught the tutorial and tell me the solution of it,i am using 30days hosted server of thingworx.
https://www.udemy.com/learning-internet-of-things-with-thingworx/learn/v4/t/lecture/8208178?start=45
Unfortunately I don't have access to the tutorial in question. However I have found an article that might be helpful to you https://www.ptc.com/en/support/article?n=CS249622
If you have specific code samples I can also take a look and see if I can spot the problem.
Is the connection working at all or is it just a problem about send / receive requests?
Thanks in advance.
Pascal
Hi @rohittrivedi
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark the answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
