Sep 29, 2025 3:55 AM UTC
Unable to connect to an external Database using Thingworx
Hello
With reference to this tip, I am not able to connect to external database
In properties section of DB Thing it is showing as not connected
But somehow some services are getting executed
Oct 8, 2025 1:15 PM UTC
Hey Rocko,
Thanks for the suggestion yes the "connectionValidationString" was correct the issue got resolved after restarting Tomcat and the "isConnected" property got checked.
Thanks.
Rocko
Sep 29, 2025 6:01 AM UTC
First off, if the services are executed as you say, and deliver a result, I think we can consider the DB as connected.
Second, to make the "isConnected" work, you need to provide a proper test query when setting up the DB connection. Check "connectionValidationString" in the configuration tab.
VV_924035912-AmethystAuthorAnswer
Hey Rocko,
Thanks.
