Dec 10, 2015 8:21 PM UTC
Unable to connect to EMS on Win7
Anybody see the obvious in what I am missing here?
I start WSEMS on my Windows 7 machine with loglevel turned on to VERBOSE
It uses the following config.json (sensitive fields xxxxx’ed) and the websocket connects and is open up to the cloud platform.
                "ws_servers":     [{
                                              "host":  "xxxxx.cloud.thingworx.com",
                                              "port":   443
                "ws_connection":             {
                               "encryption":      "ssl",
                               "verbose":           true
                "certificates":     {
                               "validate":           false
                "appKey":            "xxxx-xxxxxx-xxxxxxxx"
When I try to address the EMS from browser on the same machine as the EMS https://localhost:8000/ThingWorx/Things
Connection is refused and I see the following in the wsems trace:
[AUDIT] 2015-12-10 15:04:36,580 SDK: twWs_Connect: Websocket connected!     <<-- Next two lines show the websocket connected (EMS is running)
[INFO ] 2015-12-10 15:04:36,674 Main: Succesfully connected.  Saving .booted config file <<-- Assume all is well at this point...
[DEBUG] 2015-12-10 15:04:42,372 TlsStream:: doopen: Setting SO_RCVTIMEO   <<-- This is what I get when try to connect with browser
[TRACE] 2015-12-10 15:04:42,372 TlsStream:: doopen: Non-SSL server socket opened
[TRACE] 2015-12-10 15:04:42,372 httpServer: Allocating new client: 1
[TRACE] 2015-12-10 15:04:42,372 client_thread::execute: Starting request handler thread 2
[DEBUG] 2015-12-10 15:04:42,372 TlsStream:: doclose: Disconnecting socket   <<-- Eventually fails and Chrome web browser displays "SSL Connection Error"
Dec 13, 2015 11:04 AM UTC
Beck, under the certificates section, try adding the 'allow self signed' certificates section. Here is an example snippet:
"certificates":  {
                        "validate":       false,
                        "allow_self_signed": true
Feb 6, 2016 9:56 PM UTC
The connection settings for the websocket (which connects to the ThingWorx server) and the REST API are separate.  The REST API defaults to listening on localhost:8000 as you are using, but it defaults to HTTP not HTTPS.  You can enable HTTPS in config.json.  Look at the "http_server" section.
