Mar 23, 2020 10:19 AM UTC
Unable to convert complex JSON object into infotable using parsley extension
I am using ParseJSON method for Parsley extension.
It gives me one row properly inserted into infotable if we run this method on simple json like:-
                "input1":"{\"name\":\"MichaelJordan\",\"age\":\"38\",\"address\":\"Noida\" }"
But it fails to insert any row when we run this method on complex JSON:-
                "input2":"{\"name\":\"TestUser123\",\"age\":\"54\",\"address\":\"{\"street\":\"main street\",\"city\":\"Ggn\",\"pin\":\"202021\"}\"}"
and gives blank row.
Could somebody help me how to insert this json into infotable as well?
Thanks in advance.
PaiChungAnswer
22-Sapphire I
Mar 23, 2020 8:08 PM UTC
Have you thought of just creating your own parsing code.
JSON is recognized as an object in Thingworx and you can use es 4 / es 6
So if you know the structure you can fairly easily create your own parsing code.
PaiChung22-Sapphire IAnswer
22-Sapphire I
Support
Apr 3, 2020 8:17 PM UTC
Hi @ranjank.
If you found the previous response to be an acceptable solution, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
