Jamal Ashraf
Unable to delete Row from infotable with function myInfoTable.RemoveRow(rowIndex);
let entry = Things["Allied_Entries_SCW1.DT"].GetDataTableEntryByKey({key:"1713786015000SCW1E-AS-02"});
logger.info(entry.rows);
entry.rows[0].versionData.RemoveRow(0);
versionData is an infotable but i am still not able to remove the row with its index. As you can see this is an infotable why i am unable to remove it. any idea please?
FURTHER TESTING
I am removing row and updating that entry with removing that row but it is removing row at run time means i get what i want as an output but it not updating it in datatable. Anyone has an idea?
You need to update again into the data table.
Use following services.
AddOrUpdateDataTableEntry()
or
AddOrUpdateDataTableEntries()
Jamal Ashraf
I am already doing this but it is not working as it returns the result on runtime correct but not updating the entry into datatable.
@PaiChung any idea?
let entry = Things["TestBench_Entries_SCW1.DT"].GetDataTableEntryByKey({key:"1709109105000SCW1E-SCW-EMT-06"});
 let values;
if ( entry.rows[0].versionData && entry.rows[0].versionData.rows && entry.rows[0].versionData.rows.length > 1 ) {
 let newVersionData = entry.rows[0].versionData;
 values = Things["TestBench_Entries_SCW1.DT"].CreateValues();
 values.entryTimeStamp = entry.rows[0].entryTimeStamp; // STRING [Primary Key]
 values.Location 		 = entry.rows[0].Location; // INFOTABLE
 values.Position = entry.rows[0].Position; // DATETIME
 values.entryDate = entry.rows[0].entryDate; // STRING
 values.status = entry.rows[0].status ; //"SCW1Phase4";// STRING // To change the status of the main entry
 values.tinNumber = entry.rows[0].tinNumber;// STRING
 values.versionData = newVersionData.RemoveRow(9); //entry.rows[0].versionData;// STRING
Things["TestBench_Entries_SCW1.DT"].AddOrUpdateDataTableEntry({values:values});
result = entry;
Jamal Ashraf
I got a solution for this issue which is very weird and i could not understand that why it is behaving like that but at least i have a solution now.
 let values;
 let newVersionData = entry.rows[0].versionData.RemoveRow(9); // this wil remove the row and then idk how we are updating the entry in the datatable but it is working actually
 values.versionData = entry.rows[0].tinNumber; //entry.rows[0].versionData;// STRING
result = entry;
