Mar 28, 2024 1:11 PM UTC
Unable to disable Vertical Scrollbar for the collection Widget in a mashup
I'm having the similar issue - the Collection widget scroll bar. Do let me know if you found a resolution or workaround for this issue.
Mar 28, 2024 2:06 PM UTC
Hello @Giri ,
Pls share the ThingWorx version you are on currently.
Bhawna
Giri5-Regular MemberAuthor
Mar 29, 2024 6:01 AM UTC
I'm using Thingworx 9.3.9
Apr 2, 2024 9:06 AM UTC
Hi @Giri ,
a workaround could be to disable the scrollbars with the following CSS and the custom class "noScrollbars" for the collection:
/*Custom CSS*/
.noScrollbars ::-webkit-scrollbar {
display: none;
Dec 12, 2024 2:10 PM UTC
The solution is not working for me.
Having the same Issue, help.
Thingworx version 9.6
