Unable to find analytics server thing after instaling analytics server 8.3.2
I have installed analytics server 8.3.2 on windows 10 home edition 8gb ram and intel i5 processor with 2 cores I see that there was an error during installation which said descriptive analytics service couldn't be created as there was already one present. bur analytics server installed fine. I don't see analytics server thing present after I start the server
Can you please go through this link and see if it solves your issue.
Best Regards,
Prakhar Shubham
@pshubham
Are you still getting the same issue?
Could you please confirm if you have uninstalled analytics directly without running the uninstaller? You need to check ThingWorx Analytics server installation folder and check inside Descriptive analytics folder.
You can install this with this separate installer. If @pshubham Reply was helpful, Please mark it as accepted solution.
Regards-Mohit
mahitejg1-VisitorAuthor
I uninstalled it using uninstaller present and no the links could not help me as im unable to find the exact issue when it comes to not finidnig the analytics gateway
@mahitejg
Did you run both the uninstaller? Analytics server and Descriptive Analytics.
