Aug 25, 2022 1:08 PM UTC
Unable to get the difference between two dates and times
Hi, community,
I have been spinning my wheels with getting the differenthe ce between two dates and time.
The aim is to find the duration between the time a device is turned off and when that device is turned on.
I have two different services that output a datetime value. One service outputs the time the device is turned on and the second service outputs the time the device is switched off.
I then created a third service that calculates the difference between the two times.
Below is what I wrote in my third service:
var date1 = parseDate(onTimes_Input, " dd-MMM-YYYY HH:mm");
var date2 = parseDate(offTimes_Input, " dd-MMM-YYYY HH:mm");
let result= dateDifference(onTimes, offTimes);
when I execute the above, I get the following error:
Error executing service getDuration. Message :: Invalid format: "1661387400000" - See Script Error Log for more details.
Does anyone know what this could mean?
Best Regards
Jay_nisaa 🙂
Aug 25, 2022 1:42 PM UTC
Try below code to get a difference between 2 datetime values. If parsing not required, then directly use here.
result = Math.abs(date1 - date2)/(1000 * 60); //In Minutes
Aug 25, 2022 1:29 PM UTC
Hi @Janicen,
Did you try running the dateDifference service directly with onTimes_Input and offTimes_Input?  If the result of the services that provides these values is DATETIME the value is already in milliseconds and does not need to be parsed.
Travis
Janicen16-PearlAuthor
Aug 26, 2022 9:16 AM UTC
thank you very much. This was helpful.
1. Additionally, I did a few things I want to share.
To convert the minutes to hours:
      var x = Math.abs(date1 - date2)/(1000 * 60);
      var inHours = x/60;
2. To get the time difference to display in hours and minutes (e.g., 12 hours 30 minutes):
         var hours = parseInt(x/60); ///get the absolute value of the hours without minutes (inHours).
         var minutes = Math.floor((inHours- hours)*60); ///get the absolute value of the minutes.
         let result = hours + "h"+minutes ///concatenate the hours and minute.
Best Regards
