Unable to increase size of checkbox
Thingworx 8.5.2 :
I have increased width and height of checkbox widget but couldn't increase it's size more than default size.Could you help me.
PEHOWEAnswer
@krishnakomal123 ,
Is this the type of change you would like to be able to accomplish?
I used the Visual SDK and added Custom CSS to the mashup:
#root_ptcscheckbox-13.widget-ptcscheckbox::part(box){
 	width: 28px;
 	height: 28px;
#root_ptcscheckbox-13.widget-ptcscheckbox::part(check-mark) {
 	width: 28px;
 	height: 28px;
#root_ptcscheckbox-14.widget-ptcscheckbox::part(box){
 	width: 56px;
 	height: 56px;
#root_ptcscheckbox-14.widget-ptcscheckbox::part(check-mark) {
 	width: 56px;
 	height: 56px;
In my test case the IDs of the second and third check box are "ptcscheckbox-13" and "ptcscheckbox-14". I included a second CSS to increase the size of the check to match the box. If you wanted the modification applied to all the checkbox's you would not need the "#" and the item ID.
HTH
Peter
PEHOWE17-PeridotAnswer
@krishnakomal123 ,
 	width: 28px;
 	height: 28px;
 	width: 28px;
 	height: 28px;
 	width: 56px;
 	height: 56px;
 	width: 56px;
 	height: 56px;
HTH
Peter
