Unable to install or uninstall Thingworx
I have a problem. I was installing Thingworx and it was near the end when my machine crashed. I am now in a position where I get this error when I try to install Thingworx
"You already have Thingworx Foundation for Postgres installed. Uninstall it, and then you can use this installation tool to reinstall"
Problem is, when I go to Windows "Uninstall or change a program" app, there is nothing there with a name like PTC or Thingworx. So, nothing to uninstall.
What do I do now?
apdamsAnswer
The solution appears to be to uninstall PostgresSQL and reinstall that. Then TWX install goes ahead
apdams1-VisitorAuthorAnswer
Support
Hi @apdams.
Most likely the ThingWorx database tables had already been created and populated during the initial installation attempt, preventing attempts to reinstall.  By removing and reinstalling PostgreSQL you essentially solved that problem.  You could have also dropped the tables to achieve the same level of clean-up that was needed.
Glad you were able to resolve your issue.
--Sharon
Thanks for the help here, slangley
I wonder if you could take a look at another issue I have ("Unable to Install Thingworx when grace period has expired"). This one is a total blocker for me and I would sure appreciate your input on it
Adrian
