Unable to install ThingWorx 9.1. The tomcat is not starting up
The catalina log has been closed.
I have Tomcat 9.0.37 and Java 11.0.9 in my local machine.
Also let me know how to set JAVA_OPTS using bat file as I am unable to locate "setenv.bat" file under Tomcat directory.
Kindly help.
If you don't have -Djava.library.path set then Thingworx normally crashes
Also keep in mind that if you have spaces in the path, you should put it into quotes, like
set JAVA_OPTS=-Dserver -Dd64 -XX:+UseG1GC -Dfile.encoding=UTF-8 -Djava.library.path="c:\Program Files (x86)\Apache Foundation\Apache Tomcat\webapps\WEB-INF"
You have to create setenv.bat manually in the Tomcat/bin folder and set the env. variables there, e.g.:
set JRE_HOME=c:\PTC\jre18_241
set THINGWORX_PLATFORM_SETTINGS=c:\PTC\Thingworx90_H2
set JAVA_OPTS=-Dserver -Dd64 -XX:+UseG1GC -Dfile.encoding=UTF-8 -Djava.library.path=c:\PTC\Thingworx90_H2\webapps\Thingworx\WEB-INF\extensions
set TITLE=Thingworx90_H2
As for the reason why Thingworx doesn't start... Do you have any log files in the ThingworxStorage/logs folder? In particular, ApplicationLog.log file.
ranjank1-VisitorAuthor
@DmitryTsarev ,
Have referred below link for ThingWorx 9.1 System Requirements:-
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx%2FHelp%2FSystemRequirements%2F9_1_system_requirements.html%23wwID0EMFHM
Below three are mentioned there for Java:-
• OpenJDK - Amazon Coretto 11.0.8
• Oracle Java 11.0.8 and above (eg: 11.0.x)
• Oracle Java 1.8.0_261
That'sy I installed Oracle Java 11.0.9
ThingworxStorage folder is empty till now.
Please advise.
So Tomcat crashes upon starting?
According to your logs, Thingworx deployment begins as expected and there are no more errors.
19-Dec-2020 22:26:18.940 INFO [main] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive [C:\Program Files\Apache Software Foundation\Tomcat 9.0\webapps\Thingworx.war]
19-Dec-2020 22:26:59.733 INFO [main] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
Does something change if you create setenv.bat and set options there?
Can you see the "Thingworx" folder in the "Tomcat\webapps\" folder, next to the Thingworx.war ?
