unable to license Thingworx
currently i am using Thingworx 8.4. When I try to License Thingworx offline, Thingworx stops working(is not reacheable via browser and only works again after restarting the Computer) and the License is not acquired. In the application log I get the following Errors: (1) Unable to fetch License file with device id: …   (2) Unable to connect to the PTC lincense Server. Please make sure the LicensingConnectionSettings Setting …
In the ThingworxPlatform Folder the Responsecapability file is changed to ignored.
What is the reason for this and how can I fix it?
Regards
Nestor
@WetterNestor  Is this the fresh installation or upgrade from the previous Thingworx version?
You may refer to the below articles for more information.
https://www.ptc.com/en/support/article?n=CS286956
https://www.ptc.com/en/support/article?n=CS292020
Vibhuti
Support
Hi @WetterNestor.
In addition to the suggestions made by @vangne, make sure that you only have one .bin file located in \ThingworxPlatform.
--Sharon
Hi @slangley
I double checked and it was/is the only .bin file in the folder.
Regards
--Nestor
