Unable to load DLL 'twApi.dll' error running SteamSensor in docker
Downloaded the .NET SDK and everything works fine on my windows 10 laptop.
But when running the exact same bits in a docker container, getting this error. I have tried various images such as
microsoft/aspnet
mcr.microsoft.com/dotnet/framework/sdk:4.8
docker pull mcr.microsoft.com/dotnet/framework/runtime:4.8
mcr.microsoft.com/windows/servercore:10.0.16299.1029
com.thingworx.communications.client.TwApiWrapper Error: 0 : Error initializing the .NET SDK. : System.DllNotFoundException: Unable to load DLL 'twApi.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
at com.thingworx.communications.client.TwApiWrapper.twW_SetLoggerProperties(TwApiLogLevel level, Byte isVerboseEnabled, TwLogMessageDelegate onLogMessage)
at com.thingworx.communications.client.TwApiWrapper.ConfigureTwApiLogger()
at com.thingworx.communications.client.TwApiWrapper.Initialize(ClientConfigurator config)
Unhandled Exception: System.DllNotFoundException: Unable to load DLL 'twApi.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
at com.thingworx.communications.client.ConnectedThingClient..ctor(ClientConfigurator config)
at SteamSensorConsole.SteamSensorClient..ctor(ClientConfigurator config) in C:\Users\rshrini\samples\Dotnet-SDK-5-7-6-3407-win\Example\SteamSensorConsole\SteamSensorClient.cs:line 19
at SteamSensorConsole.SteamSensorClient.Main(String[] args) in C:\Users\rshrini\samples\Dotnet-SDK-5-7-6-3407-win\Example\SteamSensorConsole\SteamSensorClient.cs:line 91
srajgopalAnswer
After installing the that Microsoft Visual C++ Redistributable for Visual Studio 2012, it works.
srajgopal1-VisitorAuthorAnswer
