Nov 25, 2019 11:51 AM UTC
Unable to push files into Git using GitBackup extension
Hi @kiran2 ,
I am struggling with the same problem.  Can you perhaps elaborate on how you used an access token to get the communication fixed?
Do you use your same username for the account and then just use the access token as password?
Nov 26, 2019 12:59 PM UTC
I've only used the Git-Extension with Bitbucket but I think the process is similar.
Yes, you use the access token instead of your password as credentials. Your username is still the same. You have to create the access token within your GitLab account (and may add the needed privileges for this token).
Dec 17, 2019 5:42 AM UTC
Hi @DanZ ,
I did create the token in by Gitlab account but I still cannot push or pull from my gitlab.  I am also not getting any error message which makes it very difficult to trouble shoot.
