Unable to Register All UI Resources : null
- 3 replies
- 2774 views
- Translate All
Hi Guys, I have a Thingworx 8.01 in a Linux, it used to be fine, but now if I login into composer, it redirect me to a blank page. I check my log and find few errors and hope I can get some advise!
Is it means some of my extension is mess up with my UI?
Thanks a lot!
2017-10-31 09:40:03.462-0500 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2017-10-31 09:40:03.802-0500 [L: WARN] [O: c.t.e.m.AssociatedEntity] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Extension jar(s) were not found in lib/common directory of the extension. Looking in deprecated directory: lib/<EntityName>. Please update your extension's metadata.xml file to contain all JarResources in the ExtensionPackage element.
2017-10-31 09:40:04.373-0500 [L: ERROR] [O: c.t.s.m.ExtensionPackageManager] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Unable To Register All UI Resources : null
Best
Liwei
