Unable to use Session Changed event in ThingWorx 8.4.2 as there are no session events
Scenario is like this:
I have a main (parent) mashup in which I have two columns. One column have a tree widget and the other column have the contained mashup widget.
Now, I am entering texts from the contained mashup (child mashup) and when clicking OK, I want to run one service on the main mashup and get the output of the service on the Tree widget which is in the left side column.
So, for this I am not able to use the session events whenever there is a change in the contained mashup parameters.
How to handle this situation without any session events? (I can not use the same parent mashup as there are 4 to 5 contained mashups which will keep on changing inside the main mashup).
Also, is this a bug in ThingWorx 8.4.2 as I could not see the session events.
Thanks and regards,
Aditya Kumar
22-Sapphire I
Please report this as a bug at support.ptc.com
As a potential work around, you could perhaps use the session value into a Mashup parameter or into a Validation/Expression
(Maybe even add the Event Router if you are monitoring multiple values)
Thanks PaiChung for the reply!
