Mar 26, 2024 2:04 AM UTC
Unable to view imported extensions
ThingWorx version: 9.3.9
Currently, we're trying to implement Building Blocks into our ThingWorx mashups to view SVGs. One of the requirements is the svgViewer extension.
While we're able to successfully import the extension and view it in the list under Manage, we're unable to see it in the widget's list upon making a mashup.
We've tried removing unused and potentially clashing widgets, but to no avail. Has anyone faced a similar problem and been able to resolve it? Thanks in advance!
Rocko
Mar 26, 2024 7:48 AM UTC
It worked for me on 9.3.9.
Here are some hints for debugging:
Try it with a new mashup, not an existing one.
Make sure you're not using a filter on the Widget tab.
Reinstall the extension and check the server logs
When opening the mashup editor, also the server logs.
When opening the mashup editor,check the client log, i.e. F12>Console.
Restart the server
Rocko
Mar 28, 2024 10:21 AM UTC
Also check for file system privileges https://www.ptc.com/en/support/article/CS368343
Emeritus
Apr 1, 2024 5:59 AM UTC
Hello @CC_11004443,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
