Update datatable Failure
This may be a basic question. But why does this fail ?, What is the right way to update ?
var values = Things["TestDataTable"].CreateValues();
values.Id = Id; //INTEGER [Primary Key]
values.Name = "Name"+Id; //STRING
var params = {
	maxItems: undefined /* NUMBER */,
	values: values /* INFOTABLE*/,
	query: undefined /* QUERY */,
	source: undefined /* STRING */,
	tags: undefined /* TAGS */
// result: INFOTABLE
var table = Things["TestDataTable"].QueryDataTableEntries(params);
if(table.length>1)
var row = table[0];
values.Attendance = 11; //NUMBER
values.RollNum = row.RollNum; //STRING [Primary Key]
values.Percent = 11; //INTEGER
values.Id = row.Id; //INTEGER [Primary Key]
values.Name = row.Name; //STRING
var params = {
	sourceType: undefined /* STRING */,
// no return
Things["TestDataTable"].UpdateDataTableEntries(params);
Hi @skumar-81 could you share what the exact error is?
