May 28, 2019 6:54 PM UTC
Update Value On Row Select In Grid-Advanced
I have an infotable that is being passed to Service-A, that service is adding additional fields to that infotable, and returning that infotable. This infotable is being passed to the Grid-Advanced widget to populate its data.
When a row is selected from this grid, I will populate a particular column in that row with a string.
I'm not sure how to accomplish this goal. I currently have Service-A going into an event router along with the result of another service, Service-B (this service takes the infotable from Service-A and populates the value, then returns the entire infotable). Service-B is called when the SelectedRowsChanged event from Service-A is triggered. However, for some reason that event is not being triggered. Any help would be greatly appreciated!
berkobAnswer
May 30, 2019 12:03 PM UTC
Well thanks for trying. I ended up having to store the result of service A into an additional mashup parameter. I think for some reason the grid doesn't work very well with receiving its data from two different sources in regards to that event triggering
22-Sapphire I
May 29, 2019 11:57 AM UTC
Not sure why you need the event router for this.
I think without the event router in between this flow probably would work fine.
berkob1-VisitorAuthor
May 29, 2019 12:18 PM UTC
Without the event router what am I supposed to do with the infotable that is returned from service B?
Edit: I tried just implementing the grid and service A, without service B. I wanted to verify that the rows from the data were actually triggering the selectedrowschanged event, but I kept seeing this error:
ERROR - Something messed up in selected rows ... we have selected rows, but subscriberInfo.selectedRows_anySelectedRows !== true
Any idea if this error is standing in the way of my goal?
22-Sapphire I
May 29, 2019 9:40 PM UTC
This is getting a little difficult to troubleshoot  I am not sure if you should be seeing selected rows or not. I believe in the advanced Grid the widget tracks that and can be returned to a service.
I was under the impression that perhaps everything could be handled server side vs. having to return two infotables to the mashup to then create a single new table from that.
