Updating time of a property in Thingworx using lua
Trying to update time of the property on thingworx using following code
ts = 1578034820000    -epoch unix time in miliseconds
local data = {}
data.value = valore
data.time = ts
data.quality = "Good"
me:setProperty(nome, nil, nil, data)
,but except time it is updating value and quality of the property.
Tried to update after converting ts into different formats, but in vain.
Thank you!
Best Regards,
Naeem
c_lowyAnswer
Hello @mnaeem ,
We just created the following article that clarifies this behavior and should help you with the issue you encountered : Timestamp is lost when pushing property from Lua Script Resource in ThingWorx.
Best regards,
Charlotte Lowy
We can reproduce this behavior and we will open a case in you name for further investigation.
mnaeem1-VisitorAuthor
Thank you @smainente ,
I really need assistance in this issue.
I'd be really thankful to you.
Best Regards,
Muhammad Naeem Akhtar
c_lowy16-PearlAnswer
Hello @mnaeem ,
Best regards,
Charlotte Lowy
