Upgrading to 9.3 Script error
Upgrading from 9.2.3 to 9.3.4
Running script "update_postgres.sh" give the following error:
/root/Downloads/9.3.4/update/common_update_utils.sh: line 89: `common_update_utils::build_version_string': not a valid identifier
System info:
RHEL 8.6
PSQL v13.8
TOMCAT 9.0.52
JAVA 11.0.13
Any direction or advise will be greatly appreciated.
ndupreezAnswer
Hi Nick
Thank you for the question.
I was using "sh" to run the script.
It is working with "bash" ,
eg.  ./update_postgres.sh
If it still doesn't work, also remeber to make the scrip executable.
Kind Regards
Niel
@ndupreez ,
Can you share the command you're using to run that script?  And just to be clear, you're on step "E" on this page, correct?
https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Installation/Installation/manual_inplace_upgrade_windows_9.3.html#wwID0ELBUT
-Nick
ndupreez12-AmethystAuthorAnswer
Hi Nick
Kind Regards
Niel
