Upload of multiclass classification dataset
How to upload multiclass classified dataset into Thingworx analytics . When i try to import, it showing error and not allowing to import more than two class dataset. ( True/false )
We have properties in String type in a dataset, and these properties contain more than 2 values, and this won't affect the import to the Analytics server.
For example:
Property Name: CoolDownType
Value:  Water; Air; Oil    etc.
What's your dataset look like?
VijayanR1-VisitorAuthor
We have explored your suggestion and  we found the following observation.
  1. Data upload is possible for multiclass with Option(a) : String & categorical & Option (b): String & continuous
  2. Model building is possible with only option(b)
  3. Here problem is ThingWorx analytics converts the Classification problem to regression problem.
  4. Sample dataset is given below (Few rows are mentioned )
Speed
Flow
Head
torque
faults
1
2707.4
14.778
44.66
16.045
broken_blade
2
2965.6
33.591
16.438
7.5257
cavitation
3
2874.8
39.92
9.7401
10.019
healthy
If you have the TWA Extension Package with you, and you'll be able to find the sample dataset like BeanPro and Parking.  The expected goal field for these 2 datasets are Numeric type, and we can use the Categorical properties as dependencies for prediction.
