Upload picture directly from Microsoft Surface Pro 4
Hello all,does anyone know or already had to deal with uploading in thingworx a picture captured directly from dhe camera of a Surface Pro? on other tablets is already possible to do it thanks to File Upload widget, but not on this device
Support
Hi @MariusNegru.
We wouldn't expect this to be any different than another device running Windows.  Normally, images are stored in the C:\Users\<userID>\Pictures\Camera Roll folder.  You should be able to access this folder unless the permissions prevent it using the File Upload widget as long as it's visible to the ThingWorx server.
When you say it doesn't work on the Surface Pro, are you getting an error?
--Sharon
Support
Hi @MariusNegru.
Please let us know if you have resolved your issue.  If so, it would be greatly appreciated if you would post the solution here for the benefit of others on the community.
--Sharon
