URL Masking for ThingWorx REST Service
As per my understanding, ThingWorx services can be exposed as REST, but URI would be /Thing/ThingName/Services/ServiceName.
Exposing services in this way could expose business data/entities as well.
My question is that, can we MASK thingworx service URL in a custom or a REST way i.e. /resources ?
I actually tried this one time with a URL Rewrite called 'Tuckey' but I couldn't make it work, so it may not be possible. But that is what I would recommend. 'Theoretically' it could work, but when I tried it, I couldn't make it work, although I didn't go very deep.
esirohi1-VisitorAuthor
Thanks for replying.
As you mentioned that you tried URL Rewriting, what error/issues you encountered? I will also try out at my end.
I think, the changes can be made in domain setup (probably CNAME or URL Forwarding/Redirection) which can redirect a domain to another URL.
It's been a rather long time so I don't remember.
7-Bedrock
September 29, 2015
This simple nginx configuration works for me:
worker_processes  1;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    sendfile        on;
    keepalive_timeout  65;
    server {
        listen       80;
        server_name  localhost;
          location / {
               proxy_pass       http://localhost:8080;
               proxy_set_header Host      $host;
               proxy_set_header X-Real-IP $remote_addr;
          location /service {
               proxy_pass http://localhost:8080/Thingworx/Things/Neuron/ServiceDefinitions/GetConfigurationTables;
It exposes "GetConfigurationTables" service as http://localhost/service, while forwarding the rest of the requests to the port 8080.
Does the reverse proxy approach still work with a websocket connection from the edge? I was under the impression that reverse proxy broke websockets.
7-Bedrock
December 6, 2016
Nginx supports websockets in reverse proxy mode under certain circumstances, needs to be tested with EDGE SDK: WebSocket proxying
