Use parameter in Thing Template property binding
Hi everyone,
I am working on a project where I have 10 entities with the same (about 30) properties, and I would like to use Thing Template for the development. All these entities need to be remote things connected through an Industrial Gateway object. I would really like to avoid manually using the "Manage Binding" for 10 things of 30 properties each, which could potentially change in the future.
The only thing to modify in each entity would be the numbering in the Source field for all the properties (i.e. Temp01 in Thing01, Temp02 in Thing02,... etc): is there any way I can make that number into a parameter I can simply set for each of the things created off the initial template?
PaiChungAnswer
22-Sapphire I
You can create a script to set the bindings.
PaiChung22-Sapphire IAnswer
22-Sapphire I
