Use PredictionThing to perform real time scoring
I would like to use the PredictorThing to perform scoring with the RealtimeScore service in order to be able to use this service via the REST API.
I want to provide the data input temporally without the need to save a (small) dataset every time. But I don't know excatly how do I have to pass the datasetRef InfoTable correctly, when I want to pass the input parameters as json/in body. In the nested InfoTable of the metadata field, I pass the fieldnames, optype, dataType etc, and in the value fieldname, I pass the data corresponding to the field, beginning with the oldest value. Back in the datasetRef Infotable, I pass "json" as format and "body:/" at dataSetUri.
I get the following error message:
Could not process request: [Unable to process JSON [refer to logs for more details]]
This is the json body of the request:
	"modelUri": "results:/models/d081b9f3-fcd2-4f94-b839-07f8961b6d63",
	"datasetRef": {
		"created": 1521639099629,
		"description": "",
		"name": "Infotable",
		"dataShape": {
			"fieldDefinitions": {
				"filter": {
					"name": "filter",
					"aspects": {},
					"description": "SQL WHERE clause to refine the dataset",
					"baseType": "STRING",
					"ordinal": 3
				"datasetUri": {
					"name": "datasetUri",
					"aspects": {},
					"description": "Location of the data",
					"ordinal": 1
				"metadata": {
					"name": "metadata",
					"aspects": {
						"dataShape": "AnalyticsDatasetMetadata"
					"description": "Metadata of the dataset (for providing data as part of request)",
					"baseType": "INFOTABLE",
					"ordinal": 6
				"data": {
					"name": "data",
					"aspects": {},
					"description": "An infotable of data (must be flat. for providing data as part of request)",
					"ordinal": 5
				"format": {
					"name": "format",
					"aspects": {},
					"description": "Structure of the data (CSV,PARQUET,CLQUET)",
					"ordinal": 2
				"exclusions": {
					"name": "exclusions",
					"aspects": {
						"dataShape": "GenericStringList"
					"description": "Fields to remove from the dataset",
					"ordinal": 4
			"name": "AnalyticsDatasetRef",
			"description": "Reference to a dataset"
		"rows": [{
				"datasetUri": "body:/",
				"metadata": {
					"created": 1521639557758,
					"description": "",
					"dataShape": {
							"timeSamplingInterval": {
								"name": "timeSamplingInterval",
								"aspects": {},
								"description": "Time between observations in a Temporal field",
								"baseType": "INTEGER",
								"ordinal": 7
							"isStatic": {
								"name": "isStatic",
								"aspects": {
									"defaultValue": false
								"description": "If true, this field remains unchanged over time",
								"baseType": "BOOLEAN",
								"ordinal": 8
							"fieldName": {
								"name": "fieldName",
								"aspects": {},
								"description": "Name of the field",
								"ordinal": 1
							"min": {
								"name": "min",
								"aspects": {},
								"description": "Minimum observed value for Continuous fields",
								"baseType": "NUMBER",
								"ordinal": 4
							"max": {
								"name": "max",
								"aspects": {},
								"description": "Maximum observed value for Continuous fields",
								"ordinal": 5
							"dataType": {
								"name": "dataType",
								"aspects": {},
								"description": "Format of the data (STRING,DOUBLE,BOOLEAN,INTEGER)",
								"ordinal": 2
							"opType": {
								"name": "opType",
								"aspects": {},
								"description": "Behavior of the data (CONTINUOUS,CATEGORICAL,ORDINAL,BOOLEAN,TEMPORAL,ENTITY_ID)",
								"ordinal": 3
							"values": {
								"name": "values",
								"aspects": {
								"description": "Collection of possible values for Ordinal and Categorical fields",
								"ordinal": 6
						"name": "AnalyticsDatasetMetadata",
						"description": "Metadata describing the fields of a dataset"
					"rows": [{
							"isStatic": false,
							"fieldName": "asset_id",
							"dataType": "STRING",
							"opType": "ENTITY_ID",
							"values": {
								"created": 1521639563486,
								"description": "",
								"dataShape": {
										"item": {
											"name": "item",
											"aspects": {
												"isPrimaryKey": true
											"description": "Item",
											"ordinal": 0
									"name": "GenericStringList",
									"description": "Generic data shape to hold a list of strings"
								"rows": [{
										"item": "test"
										"item": "test"
										"item": "test"
										"item": "test"
										"item": "test"
										"item": "test"
										"item": "test"
										"item": "test"
							"isStatic": false,
							"fieldName": "A",
							"dataType": "DOUBLE",
							"opType": "CONTINUOUS",
							"values": {
								"created": 1521639564074,
								"description": "",
								"dataShape": {
										"item": {
											"name": "item",
											"aspects": {
											"ordinal": 0
								"rows": [{
										"item": "1"
										"item": "3"
										"item": "5"
										"item": "7"
										"item": "9"
										"item": "11"
										"item": "13"
										"item": "15"
							"isStatic": false,
							"fieldName": "B",
							"values": {
								"created": 1521639564675,
								"description": "",
								"dataShape": {
										"item": {
											"name": "item",
											"aspects": {
											"ordinal": 0
								"rows": [{
										"item": "1"
										"item": "3"
										"item": "5"
										"item": "7"
										"item": "9"
										"item": "11"
										"item": "13"
										"item": "15"
							"isStatic": false,
							"fieldName": "C",
							"values": {
								"created": 1521639566311,
								"description": "",
								"dataShape": {
										"item": {
											"name": "item",
											"aspects": {
											"ordinal": 0
								"rows": [{
										"item": "1"
										"item": "2"
										"item": "3"
										"item": "4"
										"item": "5"
										"item": "6"
										"item": "7"
										"item": "8"
							"timeSamplingInterval": 1,
							"isStatic": false,
							"fieldName": "time",
							"opType": "TEMPORAL",
							"values": {
								"created": 1521640129762,
								"description": "",
								"dataShape": {
										"item": {
											"name": "item",
											"aspects": {
											"ordinal": 0
								"rows": [{
										"item": "1"
										"item": "2"
										"item": "3"
										"item": "4"
										"item": "5"
										"item": "6"
										"item": "7"
										"item": "8"
							"isStatic": false,
							"fieldName": "failure",
							"dataType": "BOOLEAN",
							"opType": "BOOLEAN",
							"values": {
								"created": 1521641692805,
								"description": "",
								"dataShape": {
										"item": {
											"name": "item",
											"aspects": {
											"ordinal": 0
								"rows": [{
										"item": "0"
										"item": "0"
										"item": "0"
										"item": "0"
										"item": "0"
										"item": "0"
										"item": "0"
										"item": "0"
				"format": "json",
				"exclusions": {
					"created": 1521639557815,
					"description": "",
					"dataShape": {
							"item": {
								"name": "item",
								"aspects": {
								"ordinal": 0
					"rows": []
	"goalField": "ttf",
	"preferredCategoricalValues": {
		"created": 1521639099684,
		"description": "",
		"dataShape": {
				"item": {
					"name": "item",
					"aspects": {
					"ordinal": 0
		"rows": []
cmorfinAnswer
Hi
Apologies for late answer.
I have written an article that covers how to score data from the body of a REST call. It is available at https://www.ptc.com/en/support/article?n=CS282398 .
It does contains a sample dataset and scoring json request which is probably the most useful part of the article.
I believe you can use this to amend your rest call.
Note when scoring time series , you do need to pass an amount of data that is at least equal to the Lookback window of your model (see https://support.ptc.com/help/thingworx_hc/thingworx_analytics_8/#page/thingworx_analytics_8%2Ftwxa-time-series.html).
These values need to be passed in the data field not the metadata one.
hope this helps
Christophe
Hi
Just to let you know I am checking on this ... no answer as yet but  I will post as soon as I have something useful.
Thank you
Kind regards
Christophe
cmorfin19-TanzaniteAnswer
Hi
hope this helps
Christophe
