Using a Mashup Parameter as the Query Filter?
How can I include a parameter passed into the mashup as the input to a query?
For example:
  1. MashupA has a mashup parameter named “PassedSiteId”
    2. The mashup uses the query service “QueryImplementingThingsWithData”.  (Note: SiteId is one of the properties of the instantiated Things and I want to filter on that).
So I want the query in the “QueryImplementingThingsWithData” to be:   SiteId = PassedSiteId
I only see how to place hard coded literals in the query target.
Any pointers to documentation or examples?
qn_01Answer
You can create a new service with an input "SiteIdParam". This service executes the "QueryImplementingThingsWithData" with the query which contains "SiteId = SiteIdParam".
Then, in the mashup, you can bind the mashup parameter "PassedSiteId" to the input parameter "SiteIdParam" of this new service.
qn_011-VisitorAnswer
This works.  Thanks for the input.
