7-Bedrock
Using button widget, how to write the PLC tags boolean from thing Worx to kepserver
i want to write the plc tag value from thingworx to kepserver using button widget.  I have added the properties of tag, tested by changing value 0 or 1, in kepserver the tag value is changing.  But when i tried with button widget, no success,  I dont know how to bind the button widget output to remote thing properties? or should i need service to write the value?
Thingworx 9.3
PLC s7-1200
KepseverEX
is used.
Arun_CAnswer
Hi @JSPM ,
Based on Button's clicked event you can execute "Expression" with Output of Boolean as true/false to set property value in RemoteThing. Otherwise you can also check with other widget of "CheckBox" or "Toggle Button" for boolean state outputs.
Thanks & Regards,
Arun C
Arun_C16-PearlAnswer
Hi @JSPM ,
Thanks & Regards,
Arun C
