Using IF statement to change the value of a property
I am trying to change the value of a property depending on the value of another property. I have used the code below within a subscription.
if(me.Amplitude = 1) {
me.Condition = "Normal Operation"
else if(me.Amplitude = 2) {
me.Condition = "Bearing Fault"
else {
me.Condition="Error"
When I test the code my Condition property changes to 'Normal Operation' but remains on 'Normal Operation' regardless of the value I assign to Amplitude.
Hope you can help.
Thanks, James
The single equals sign = is an assignment operation which evaluates to True. The double equals == is an equality test.
One technique to avoid getting burned by this type of error is to put the constant on the left:
if( 1 = me.Amplitude ) {...
That would have thrown an error until you fixed it with the double equals sign
