Apr 8, 2024 9:12 AM UTC
using ptcsgrid for displaying a tree grid
hello all,
I'm using thingworx 9.5 and I'm trying to configure it for displaying a tree, It's not clear for me the needed infotable and how I need to configure the ptcsgrid widget for this.
any hint, example, tutorial, documentation is apreciated
Apr 8, 2024 10:17 AM UTC
Hi, @AK_10638440  Can you take a look at the below article and let us know if it will work in your case or not?
https://www.ptc.com/en/support/article/CS329539
Apr 8, 2024 10:38 AM UTC
Hi Surya,
the tree grid advanced you proposed is a legacy widget in Thingworx 9.5. I'm trying to use the new grid widget which can be used for a tree view also, but I'm not sure how
Apr 8, 2024 11:54 AM UTC
Hi @AK_10638440  Thingworx has a tree widget also, can you take a look if it can fulfill your use case, I will try your above scenario and let you know my findings.
