Using the C SDK to Deliver Data to ThingWorx from a Raspberry PI
Hi @AkshayKumar I am facing this error
pi@raspberrypi:~/Documents/c-sdk-2.2.12.1052-development/cmake/examples/SteamSensor $ ls
CMakeFiles           libcrypto.so.1.1  Makefile
cmake_install.cmake  libssl.so.1.1     SteamSensor
pi@raspberrypi:~/Documents/c-sdk-2.2.12.1052-development/cmake/examples/SteamSensor $ ./SteamSensor
[FORCE] 2021-10-02 21:01:00,335: Starting up...
[WARN ] 2021-10-02 21:01:00,336: SDK Version: 2.2.12
[WARN ] 2021-10-02 21:01:00,336: TLS Library: OpenSSL
[WARN ] 2021-10-02 21:01:00,336: TLS Library Version: 1.1.1j
[DEBUG] 2021-10-02 21:01:00,336: twWs_Create: Initializing Websocket Client for https://PP-2110022216B3.portal.ptc.io/Thingworx:443/Thingworx/WS
[DEBUG] 2021-10-02 21:01:00,336: twTlsClient_Create: Initializing TLS Client
[WARN ] 2021-10-02 21:01:00,339: twSocket_Create: getaddrinfo() failed: [Name or service not known]
[DEBUG] 2021-10-02 21:01:00,339: twSocket_Close: socket is already closed or was never opened
[ERROR] 2021-10-02 21:01:00,339: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2021-10-02 21:01:00,339: twApi_Initialize: Error creating websocket structure, retrying
[DEBUG] 2021-10-02 21:01:05,339: twWs_Create: Initializing Websocket Client for https://PP-2110022216B3.portal.ptc.io/Thingworx:443/Thingworx/WS
[DEBUG] 2021-10-02 21:01:05,340: twTlsClient_Create: Initializing TLS Client
[WARN ] 2021-10-02 21:01:05,340: twSocket_Create: getaddrinfo() failed: [Name or service not known]
[DEBUG] 2021-10-02 21:01:05,340: twSocket_Close: socket is already closed or was never opened
[ERROR] 2021-10-02 21:01:05,340: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2021-10-02 21:01:05,340: twApi_Initialize: Error creating websocket structure, retrying
[DEBUG] 2021-10-02 21:01:10,341: twWs_Create: Initializing Websocket Client for https://PP-2110022216B3.portal.ptc.io/Thingworx:443/Thingworx/WS
[DEBUG] 2021-10-02 21:01:10,341: twTlsClient_Create: Initializing TLS Client
[WARN ] 2021-10-02 21:01:10,341: twSocket_Create: getaddrinfo() failed: [Name or service not known]
[DEBUG] 2021-10-02 21:01:10,341: twSocket_Close: socket is already closed or was never opened
[ERROR] 2021-10-02 21:01:10,341: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2021-10-02 21:01:10,341: twApi_Initialize: Error creating websocket structure, retrying
[DEBUG] 2021-10-02 21:01:15,341: twWs_Create: Initializing Websocket Client for https://PP-2110022216B3.portal.ptc.io/Thingworx:443/Thingworx/WS
[DEBUG] 2021-10-02 21:01:15,341: twTlsClient_Create: Initializing TLS Client
[WARN ] 2021-10-02 21:01:15,341: twSocket_Create: getaddrinfo() failed: [Name or service not known]
[DEBUG] 2021-10-02 21:01:15,342: twSocket_Close: socket is already closed or was never opened
[ERROR] 2021-10-02 21:01:15,342: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2021-10-02 21:01:15,342: twApi_Initialize: Could not connect after 3 attempts
[ERROR] 2021-10-02 21:01:15,342: Error initializing the API
Any thoughts/ suggestions.
Related:  post
Hello @Hanandan
Can you validate the platform URL - there is an extra "/Thingworx" before the port :
Hanandan1-VisitorAuthor
Hi @smainente  Good Catch! I did try removing the extra  "/Thingworx" but still getting the same error
my build is successful too(see below):
pi@raspberrypi:~/Documents/c-sdk-2.2.12.1052-development/cmake/examples/SteamSensor $ make
Scanning dependencies of target thirdParty
[ 0%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/cJSON/cJSON.c.o
[ 0%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/tomcrypt/src/ciphers/des.c.o
[ 0%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/tomcrypt/src/hashes/md4.c.o
[ 5%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/tomcrypt/src/hashes/md5.c.o
[ 5%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/tomcrypt/src/hashes/sha1.c.o
[ 5%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/tomcrypt/src/misc/error_to_string.c.o
[ 5%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/tomcrypt/src/misc/base64/base64_decode.c.o
[ 11%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/tomcrypt/src/misc/base64/base64_encode.c.o
[ 11%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/tomcrypt/src/misc/crypt/crypt_argchk.c.o
[ 11%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/wildcard/wildcard.c.o
[ 11%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/adler32.c.o
[ 17%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/crc32.c.o
[ 17%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/deflate.c.o
[ 17%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/gzclose.c.o
[ 17%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/gzlib.c.o
[ 23%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/gzread.c.o
[ 23%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/inffast.c.o
[ 23%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/inflate.c.o
[ 29%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/inftrees.c.o
[ 29%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/trees.c.o
[ 29%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/zutil.c.o
[ 29%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/contrib/minizip/ioapi.c.o
[ 35%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/contrib/minizip/unzip.c.o
[ 35%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/contrib/minizip/zip.c.o
[ 35%] Building C object src/thirdParty/CMakeFiles/thirdParty.dir/zlib/contrib/untgz/untgz.c.o
[ 35%] Built target thirdParty
Scanning dependencies of target twCSdk
[ 35%] Building C object src/CMakeFiles/twCSdk.dir/api/twApi.c.o
[ 41%] Building C object src/CMakeFiles/twCSdk.dir/api/twPasswds.c.o
[ 41%] Building C object src/CMakeFiles/twCSdk.dir/api/twProperties.c.o
[ 41%] Building C object src/CMakeFiles/twCSdk.dir/api/twServices.c.o
[ 41%] Building C object src/CMakeFiles/twCSdk.dir/fileTransfer/twFileManager.c.o
[ 47%] Building C object src/CMakeFiles/twCSdk.dir/fileTransfer/twFileTransferCallbacks.c.o
[ 47%] Building C object src/CMakeFiles/twCSdk.dir/messaging/twBaseTypes.c.o
[ 47%] Building C object src/CMakeFiles/twCSdk.dir/messaging/twInfoTable.c.o
[ 47%] Building C object src/CMakeFiles/twCSdk.dir/messaging/twMessages.c.o
[ 52%] Building C object src/CMakeFiles/twCSdk.dir/messaging/twMessaging.c.o
[ 52%] Building C object src/CMakeFiles/twCSdk.dir/forkedThirdParty/libcfu/src/cfuhash.c.o
[ 52%] Building C object src/CMakeFiles/twCSdk.dir/forkedThirdParty/ntlm/ntlm.c.o
[ 52%] Building C object src/CMakeFiles/twCSdk.dir/primitiveUtils/twPrimitiveUtils.c.o
[ 58%] Building C object src/CMakeFiles/twCSdk.dir/shapes/twShapes.c.o
[ 58%] Building C object src/CMakeFiles/twCSdk.dir/standardProps/twStandardProps.c.o
[ 58%] Building C object src/CMakeFiles/twCSdk.dir/stubs/twApiStubs.c.o
[ 58%] Building C object src/CMakeFiles/twCSdk.dir/subscribedProps/twSubscribedProps.c.o
[ 64%] Building C object src/CMakeFiles/twCSdk.dir/threadUtils/twThreadUtils.c.o
[ 64%] Building C object src/CMakeFiles/twCSdk.dir/tls/twConnectionInfo.c.o
[ 64%] Building C object src/CMakeFiles/twCSdk.dir/tls/twSig.c.o
[ 70%] Building C object src/CMakeFiles/twCSdk.dir/tls/twTls.c.o
[ 70%] Building C object src/CMakeFiles/twCSdk.dir/tls/twOpenSSL.c.o
[ 70%] Building C object src/CMakeFiles/twCSdk.dir/tunneling/twTunnelManager.c.o
[ 70%] Building C object src/CMakeFiles/twCSdk.dir/utils/crypto_wrapper.c.o
[ 76%] Building C object src/CMakeFiles/twCSdk.dir/utils/list.c.o
[ 76%] Building C object src/CMakeFiles/twCSdk.dir/utils/stringUtils.c.o
[ 76%] Building C object src/CMakeFiles/twCSdk.dir/utils/twDict.c.o
[ 76%] Building C object src/CMakeFiles/twCSdk.dir/utils/twHttpProxy.c.o
[ 82%] Building C object src/CMakeFiles/twCSdk.dir/utils/twLogger.c.o
[ 82%] Building C object src/CMakeFiles/twCSdk.dir/utils/twMap.c.o
[ 82%] Building C object src/CMakeFiles/twCSdk.dir/utils/twNtlm.c.o
[ 82%] Building C object src/CMakeFiles/twCSdk.dir/utils/twOfflineMsgStore.c.o
[ 88%] Building C object src/CMakeFiles/twCSdk.dir/utils/twPath.c.o
[ 88%] Building C object src/CMakeFiles/twCSdk.dir/utils/twTasker.c.o
[ 88%] Building C object src/CMakeFiles/twCSdk.dir/utils/twZipTar.c.o
[ 88%] Building C object src/CMakeFiles/twCSdk.dir/websocket/twWebsocket.c.o
[ 94%] Building C object src/CMakeFiles/twCSdk.dir/porting/twPThreads.c.o
[ 94%] Building C object src/CMakeFiles/twCSdk.dir/porting/twLinux.c.o
[ 94%] Building C object src/CMakeFiles/twCSdk.dir/porting/twApiWrapper.c.o
[ 94%] Linking C shared library libtwCSdk.so
[ 94%] Built target twCSdk
Scanning dependencies of target SteamSensor
[ 94%] Building C object examples/SteamSensor/CMakeFiles/SteamSensor.dir/src/main.c.o
cc1: warning: option ‘-mstructure-size-boundary’ is deprecated
/home/pi/Documents/c-sdk-2.2.12.1052-development/examples/SteamSensor/src/main.c: In function ‘main’:
/home/pi/Documents/c-sdk-2.2.12.1052-development/examples/SteamSensor/src/main.c:179:43: warning: passing argument 1 of ‘twApi_RegisterOnAuthenticatedCallback’ from incompatible pointer type [-Wincompatible-pointer-types]
twApi_RegisterOnAuthenticatedCallback(authEventHandler, TW_NO_USER_DATA);
In file included from /home/pi/Documents/c-sdk-2.2.12.1052-development/src/shapes/twShapes.h:19,
from /home/pi/Documents/c-sdk-2.2.12.1052-development/src/api/twExt.h:6,
from /home/pi/Documents/c-sdk-2.2.12.1052-development/examples/SteamSensor/src/main.c:8:
/home/pi/Documents/c-sdk-2.2.12.1052-development/src/api/twApi.h:813:56: note: expected ‘authEvent_cb’ {aka ‘void (*)(char *, char *, void *)’} but argument is of type ‘void (*)(char *, void *)’
int twApi_RegisterOnAuthenticatedCallback(authEvent_cb cb, void * userdata);
[100%] Building C object examples/SteamSensor/CMakeFiles/SteamSensor.dir/src/SteamThing.c.o
[100%] Linking C executable SteamSensor
Copying openssl to test directory.
[100%] Built target SteamSensor
CMakeFiles cmake_install.cmake libcrypto.so.1.1 libssl.so.1.1 Makefile SteamSensor
but again same error (see below):
[FORCE] 2021-10-04 14:00:04,126: Starting up...
[WARN ] 2021-10-04 14:00:04,127: SDK Version: 2.2.12
[WARN ] 2021-10-04 14:00:04,127: TLS Library: OpenSSL
[WARN ] 2021-10-04 14:00:04,127: TLS Library Version: 1.1.1j
[DEBUG] 2021-10-04 14:00:04,127: twWs_Create: Initializing Websocket Client for https://PP-2110022216B3.portal.ptc.io:443/Thingworx/WS
[DEBUG] 2021-10-04 14:00:04,127: twTlsClient_Create: Initializing TLS Client
[WARN ] 2021-10-04 14:00:04,130: twSocket_Create: getaddrinfo() failed: [Name or service not known]
[DEBUG] 2021-10-04 14:00:04,130: twSocket_Close: socket is already closed or was never opened
[ERROR] 2021-10-04 14:00:04,130: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2021-10-04 14:00:04,130: twApi_Initialize: Error creating websocket structure, retrying
[DEBUG] 2021-10-04 14:00:09,130: twWs_Create: Initializing Websocket Client for https://PP-2110022216B3.portal.ptc.io:443/Thingworx/WS
[DEBUG] 2021-10-04 14:00:09,130: twTlsClient_Create: Initializing TLS Client
[WARN ] 2021-10-04 14:00:09,131: twSocket_Create: getaddrinfo() failed: [Name or service not known]
[DEBUG] 2021-10-04 14:00:09,131: twSocket_Close: socket is already closed or was never opened
[ERROR] 2021-10-04 14:00:09,131: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2021-10-04 14:00:09,131: twApi_Initialize: Error creating websocket structure, retrying
[DEBUG] 2021-10-04 14:00:14,131: twWs_Create: Initializing Websocket Client for https://PP-2110022216B3.portal.ptc.io:443/Thingworx/WS
[DEBUG] 2021-10-04 14:00:14,131: twTlsClient_Create: Initializing TLS Client
[WARN ] 2021-10-04 14:00:14,131: twSocket_Create: getaddrinfo() failed: [Name or service not known]
[DEBUG] 2021-10-04 14:00:14,131: twSocket_Close: socket is already closed or was never opened
[ERROR] 2021-10-04 14:00:14,131: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2021-10-04 14:00:14,131: twApi_Initialize: Error creating websocket structure, retrying
[DEBUG] 2021-10-04 14:00:19,131: twWs_Create: Initializing Websocket Client for https://PP-2110022216B3.portal.ptc.io:443/Thingworx/WS
[DEBUG] 2021-10-04 14:00:19,132: twTlsClient_Create: Initializing TLS Client
[WARN ] 2021-10-04 14:00:19,132: twSocket_Create: getaddrinfo() failed: [Name or service not known]
[DEBUG] 2021-10-04 14:00:19,132: twSocket_Close: socket is already closed or was never opened
[ERROR] 2021-10-04 14:00:19,132: twWs_Create: Error creating BSD socket to be used for the websocket
[ERROR] 2021-10-04 14:00:19,132: twApi_Initialize: Could not connect after 3 attempts
[ERROR] 2021-10-04 14:00:19,132: Error initializing the API
Support
October 20, 2021
Hi @Hanandan.
There could be a number of causes, e.g. wrong port, firewall config, etc.  You're also testing using SSL,  You could start there by turning that off to see if the problem might be related to the certificate or configuration.
--Sharon
Hi @slangley thanks for the response. Do you know any article or steps needed for the configuration. BecauseI used the document (Getting Started with The ThingWorx C SDK on the Raspberry PIhttps://community.ptc.com › iottechtips › UsingT...) from PTC to start with and it did not cover these information. Also, I will try as per your suggestion.
Support
October 28, 2021
Hi @Hanandan.
The document you referenced is very old.  You might be more successful by using this one.
We also noticed in the error message that you're using port 443, which is a secured port, but the protocol is unsecured (WS).  Have you tried with WSS?
--Sharon
