V2 equivalent of context.getDevice
  • March 18, 2015
  • 2 replies
  • 914 views
Is there a V2 equivalent of context.getDevice that will return an Asset instead of a V1 Device object? If not, what would be the recommended method for obtaining the Asset object when a Custom Object is triggered by an Expression Rule?
Thanks!
Alan
    Unfortunately there is no way to get a v2 equivalent without fetching it back again as of the latest version of the Axeda Platform 6.8.
    I would simply do:
    import static com.axeda.sdk.v2.dsl.Bridges.*
    Asset v2Asset = assetBridge.findById(context.getDevice().getId().toString())
    //use the v2Asset
    I recognize that's less than ideal but it'd work fine.
    Cheers,
    -Clint
    ablyth10-MarbleAuthor
    Lovely one-liner,
    Thanks Clint, i was hoping you'd be around and provide an excellent answer as always!
    Alan,
