value stream and stream?
How  Can we integrate with a mashup?
@VS_10112707
For value streams you can use QueryPropertyHistory service, it queries the value stream for logged property values, along with filter and sort criteria, and normalizes the data set to display results for a given time range. There are other services as well, you can refer this help center guide for details.
For streams you can use GetStreamData service to get all the data in the stream. Other services are mentioned in this guide.
Sachin Sharma
Hi @VS_10112707 ,
I am not able to understand the query. Can you please elaborate it more?
Regards
Bhawna
value stream and stream data storage what is the exact use case? and can we connect it with thingworx mashup builder?
