valuedisplay widget
I use a value display widget to make it red if it's smaller than 10, and
bigger than 10, smaller than 20 blue, finally
bigger than 20, smaller than 30 green.
What can I do?
raluca_edu
You can use state base formatting , if you are using valuedisplay widget (not ptcs-valuedisplay).
State base should look like this in Properties of widget > Value Format (this is an example, you need to adjust the values):
Hope it helps,
Raluca Edu
raluca_edu
Hope it helps,
Raluca Edu
JackEom1-VisitorAuthor
Thank you for answering me, Raluca Edu.
but Like the photo 'test2" I don't see the "< "as you
I worked with Photo "test"
Is it right to do this?
raluca_edu
It is ok as in 'test' image, you need to create state definition first.
Sorry, I forgot to mention you that.
Raluca Edu
