Values not saved when using MQTT
Hi, I am using the MQTT template to subscribe to MQTT values, but when I query for property history I only get the values which I set manually. I think it's a permission problem. Any help is appreciated. Thank you!
BSUN_ROAnswer
22-Sapphire I
Do you have the 'DataChange' for the MQTT mapped property set to Always?
(Besides that, is it logged)
BSUN_RO1-VisitorAuthor
Yes, it's set to Always. I set also Persist and Log.
22-Sapphire I
Not too sure then what the issue might be, as an alternative you can log it from a subscription to the datachange?
BSUN_RO1-VisitorAuthorAnswer
