View Base64 PDF In ThingWorx
I am trying to view base64 pdf using thingworx mashup.
Came across old message that helped me view the pdf using a value display widget
https://community.ptc.com/t5/ThingWorx-Developers/How-to-show-base-64-content-of-PDF-in-Thingworx-Mashup/m-p/723472#M51519
The problem the value container height is 153px (width 1879) and not full screen
Tried changing min height property but did nothing.
Anyone can help view a base64 pdf to fit window?
TomerHAnswer
Hi Arun,
Your suggestion did not fix my issue as I wanted the pdf to fit the screen.
But once I saw that using pixels indeed had effect, that gave me direction for a fix.
The problem is the widget placing the iframe inside a span, for some reason by default it is not 100%.
a little custom css did the trick and for others I will post it below.
.screen-100 .widget-ptcsvaluedisplay::part(item-value) {
width: 100%;
height: 100%;
.screen-100 .widget-ptcsvaluedisplay::part(item-value-container) {
width: 100%;
height: 100%;
.screen-100 .widget-ptcsvaluedisplay::part(value-container) {
width: 100%;
height: 100%;
.screen-100 .widget-ptcsvaluedisplay::part(overflow-control) {
width: 100%;
height: 100%;
"screen-100" is the custom css name placed in the widget CustomClass property.
Best Regards,
Tomer.
Hi @TomerH
Have you tried with the fixed height & width in pixels?
result = '<iframe src="data&colon;application/pdf;base64,'+ IP_Data+ '" height="153px" width="1879px" frameborder="0"></iframe>';
If its not okey for you. We will look for other sugestions.
 Thanks & Regards,
Arun C
TomerH12-AmethystAuthorAnswer
Hi Arun,
width: 100%;
height: 100%;
width: 100%;
height: 100%;
width: 100%;
height: 100%;
width: 100%;
height: 100%;
Best Regards,
Tomer.
HI @TomerH ,
Great its looking good & Thank you for posting your fix here.
Thanks & Regards,
Arun C
