Waterfall Chart Widget Showing Incorrect Total
- 4 replies
- 2491 views
- Translate All
I am facing an issue with the Waterfall Chart Widget where, in my InfoTable, I have 13 different fields, and while not all fields have corresponding values in the xx axis, I would like all the changes in all the fields to be accounted for in the final bar (Total). However, the total is only taking into account the first field of the InfoTable, despite showing the variations across the other fields in the chart correctly. I attached a picture of this issue.
Is there something I could be doing wrong or should I manipulate the InfoTable in some other way?
Best regards,
Manuel
