Websocket connection between Thingworx and a websocket-server.
  • September 29, 2016
  • 12 replies
  • 7587 views
Hello community,
I want to open a websocket connection between Thingworx and a websocket-server for subscribing data.
I have seen that such services for http protocol exist in Thingworx:
var result = Resources["ContentLoaderFunctions"].LoadJSON(params);
So my question is:
Is there any possibility to do almost the same via websocket communication?
Thanks a lot for help,
Max
Why aren't you just using the EMS or one of the SDKs, which handle the websocket communication for you?
mrenner1-VisitorAuthor
Thanks for comment.
Yes I could handle the websocket communication using one of the SDKs.
But I thought there will be an out of the box solution for websockets in thingworx.
Do you know if there is any way to do this out of the box?
The EMS is out of the box. It only needs to be configured. Here, check out the Developer's Guide and let me know if you have further questions on this.
