Jamal Ashraf
Jun 19, 2024 9:30 AM UTC
Weird behaviour Thingworx project dependencies
I have one query regarding the project dependencies. I remove this dependencies but they come again when i come to thingworx. Can anyone pleasee let me know why they are coming even though they are not dependent on this project but still these dependenices which are other projects comes here.
Jun 19, 2024 10:03 AM UTC
Hi, @MA8731174  Check the dependent entities, in the project field, if it does not add any project then share with us the export of the project for analysis purposes.
Jamal Ashraf
Jun 27, 2024 4:18 AM UTC
I have check in the project entities and there is not a single entity which is dependent on another project but still these dependencies just come when i import project from one server to another then it comes again there into that project.
Jul 1, 2024 6:45 AM UTC
Hi @MA8731174 ,
1. Did you try to remove the project dependencies in the original server, then SAVE, then export and this issue remained the same?
From what I want to make sure that you clicked Save after you removed them in the original server, before importing in the new server.
2. If you remove the dependencies in the NEW server, then SAVE, do the dependencies disappear? What if you restart your NEW server after doing what I wrote before, are they still missing?
3. You wrote "import project". What exactly are you importing? Is it just the Project Entity? Or a big XML containing the Project and all associated entities from it? Or via Source Control Entities?
Emeritus
Jun 26, 2024 2:00 PM UTC
Hello @MA8731174,
I wanted to let you know that there is a response to your topic.
If you are in a position to respond to this question, that would be great.
Thanks for supporting the PTC Community,
Vivek N
Community Moderation Team.
