3-Newcomer
What does it mean SelectedRows in the output of a service ?
Hi
Thank you
Arun_CAnswer
Hi @MH_10493873 ,
SelectedRows binding is used when you have bound the "All Data" from a service to a widget like a dropdown, grid, charts or simply infotable based widgets.
Then when you select something in those widgets, you will end up with data in the services "SelectedRows" bindings as input fields, also based on "SelectedRowsChanged" you can perform any specific functionalities.
Hope it clarifies you.
Thanks & Regards,
Arun C
Arun_C16-PearlAnswer
Hi @MH_10493873 ,
Thanks & Regards,
Arun C
