What is causing this? "Could not set properties on server. code: 500, resp:"
What does the following line mean?
"[INFO ] 2019-04-17 00:18:48,841 CrewRover1_wwong: Attempting to GetPropertySubscriptions from server failed. code: 500, result:"
I keep getting this line in my LSR log, but i'm not sure what it means.
Another line I'm not sure about is....
"[WARN ] 2019-04-17 00:19:11,60 thingworx.server: Could not set properties on server. code: 500, resp:"
What is causing these lines?  Does it mean that my EMS and LSR are not bound correctly?
How can I fix these?
Please see the attached LSR log file for the full log.
WillieAnswer
Never mind.  It was a visibility permissions issue.  It's working fine now after adding the org unit with the user group to the visibility instance of the thing template.
Willie16-PearlAuthorAnswer
Support
Hi @Willie.
Since you found a solution to your issue, please mark your follow-up reply as the Accepted Solution for the benefit of users with the same issue.
--Sharon
