What is Persistent session?
Hi guys,
out of nowhere this appeared under my RemotThings Monitor.
I am sure that I have not connect any"thing" like it? What it could be? I recently made one mashup using GetProperties and Automatic update when able option.
It should create a web socket connection to the platform. Could it be it?
BTW. This option is not running at 100 percent. Well sometimes works, but most of the time does not. Does anybody have the same experience?
Tomas
Hi Tomas Coufal​,
Try opening the remote Thing entity and the check the change history details for which user created this entity. You might get some hint from there.
I hope it helps.
Ankit Gupta
tcoufal1-VisitorAuthor
There is no Entity.
Template is BrowserTemplate. It is coming from Mashups which they are using GetProperties service with Automatic update when able option.
More windows I open more these things will appear in my RemoteThing monitor.
T.
Tomas, it is the websocket session that gets created from checking the 'Automatically update when able' setting on your Mashup. It essentially creates and maintains a (websocket) connection as long as you are accessing that Mashup.
If you login through an incognito window, for example, and view the same Mashup, you are pretty much creating a 'new' session, so another PersistentSession Thing will pop up.
