When FileTransfer event from FileRepository thing has triggered?
Have a problem with FileTransfer event. I wrote a subscription with code like this:
if(eventData.isComplete === true){
	me.IsComplete = "true";
And after I execute some of services, but don't have any result.
I'm confused about that, because i have no idea in which cases event has triggered.
PaiChungAnswer
22-Sapphire I
You are subscribed to the FileTransfer event right?
You aren't even getting a FileTransfer start?
22-Sapphire I
I would add some script log logger statements to see what is happening. especially I believe there is a status field you can log out?
and113-AquamarineAuthor
Are you mean a thing property?
22-Sapphire I
Status should be in the event data or else associated with the transfer job.
