When to use Switch in ThingWorx Flow ?
I can create any branches without using Switch in ThingWorx Flow,   it seems this approach covers the usage of Switch.   I wonder in what kind of use case where using Switch is a must ?
Sean
seanccc17-PeridotAuthor
@mnarang ,
The link  https://support.ptc.com/help/thingworx_hc/thingworx_8_hc/en/index.html#page/ThingWorx/Help/Integration_Orchestration/DeveloperTools/Switch.html/
is a blank page.
Could you re-post the link ?  Thanks
Sean
mnarang5-Regular MemberAnswer
Support
Hi @seanccc
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
